U brakes have character. With the right pads and set up they work well. Making the old tech perform is the fun part.If I had a u brake frame I'd go hub brakes
Since when has any of this RetroBike malarkey ever made any sense?!*Well in fairness if you have a u brake frame I get using them, not really much of a choice is there. But to actively seek out ways to use a u brake when you could use a beautiful cheap modern deore v brake which not only beats every other v brake ever made but costs **** all, well, I do find that a bit doolally
Still doesn't change the fact that I wouldn't want to go to the trouble to get an adapter plate made to use an inferior brake setup. But I also subscribe to a different philosophy than many on here, and as they say different strokes for different folks.U brakes have character. With the right pads and set up they work well. Making the old tech perform is the fun part.
The clogging is an issue though. This was at the Cotswold Cross last month.
Had to keeping poking the clods out with a stick!
Wait is this Retrobike?Since when has any of this RetroBike malarkey ever made any sense?!*And often the least sensible ideas are the best, or at least that what we tell ourselves...
