drexal77
Devout Dirtbag
Hi guys,
Will try to keep to the point below as i tend to go into way to much detail and people get bored reading through.
Recently managed to buy a beautiful condition Shimano HG70 11T-28T 7 speed cassette (with red label still attached). Its for a mountain bike build i'm doing (i know it should be a 12T-28T).
Long story i wanted the 11T cog as i do a lot of flat and down hill roads and love standing up sprinting those sections as fast as i can for short burst ( i've been lectured about spinning etc and that i should stick with 12T cog etc but i really want to make this 11T work). I bought it in hurry with out researching it properly.
Now i have run into a load of issues. I want to pair it with the period correct Shimano DX FH-M650 7 speed HUB (that i haven't bought yet) but from my research (a lot of help from sheldon brown https://www.sheldonbrown.com/k7.html) he says the only way to get the 11T cog to fit to this HUB is if i buy one that is Hyperglide C version (which i'm not sure Shimano ever made this hub with a hyperglide C body) or i switch the body for a hyperglide C body. Its to do the splines being shaved off the edge of the C body which allows you to use the very small 11T cog. I've scoured the internet for hyperglide C hubs / free bodies but all it comes up is the hyperglide C cassettes. There are shimano bodies for sale that look similar to the Hyperglide C body with the splines shaved back from the edge, but they are all seem to be for 8/9/10 speed set-ups. I've searched the Shimano old parts technical drawing website, but nothing comes under hyper glide C (i think the C stands for compact, so i'm not sure if the body is shorter compared to the normal hyperglide body that comes with these hubs)?
Does any one of you own a Hyperglide C hub / body and would you happen to know the size of it? so at least i could measure it against one of these 8 speed bodies to see if they are the same size at least.
I've attached an image of the hyperglide C body and the normal hyperglide body.
If any of you can recommend a free body that would fit that i can add to the DX hub, that would be amazing.
The second issue is, i want the run the cassette & hub with the period correct RD-M650 rear derailleur, but i have just managed to find a service instruction for this derailleur and it says max cog 28T-32T & smallest cog 12T so it looks like this 11T-28T won't work with the derailleur i want to run also. Have any of you ever run a 11T cog on this exact RD-M650 rear derailleur?
Also i know sheldon says this:
But i didn't really want to buy a vintage body and then try and file the edges down. So would rather try and get a hyperglide C body. Also the chain i bought is the CN-HG71 so need to check that won't have issues with an 11T as well.
I really hope it's possible to make this work.
Thank you so much for anyone that can offer any advice here.
- Alternately, you can grind a bevel on the ends of the splines of an older body. This is a five-minute job if you have access to a bench grinder. Clean up carefully afterward so particles of metal and grinding-wheel grit don't wear out the bearings.
