vcballbat
Sorry for the delay what with Christmas now packed away... what a relief  I've got the plain unthreaded Simplex rear dropout hanger on Pugsy PX10 so nut fixed from behind, readin the 543 manual you can turn with a screwdriver and nip up the nut to adjust tension. Theres a spring inside the top barrel that can have tension in either direction so it actually is more for shock absorption and smooth shifts I'm thinking
 I've got the plain unthreaded Simplex rear dropout hanger on Pugsy PX10 so nut fixed from behind, readin the 543 manual you can turn with a screwdriver and nip up the nut to adjust tension. Theres a spring inside the top barrel that can have tension in either direction so it actually is more for shock absorption and smooth shifts I'm thinking  You could tap a thread in your hanger to take a non weird rear mech.
 The bolt is compatible with threaded or non-threaded Simplex drop-outs. The Simplex manuals most likely don't state the normal course of action is to keep fiddling with it trial and error and keep taking the wheel out and putting it in again
