Exposed cable vs Fully housed
Traditionally it was a weight saving and it also mean't less friction on the cable so a smoother shift.
The advent of ptfe lined housing put pay to the latter, although a nicely gunged up cable is still nasty in a full housing (doesn't seem to be as bad in a traditional non full housing set up, guess there is less out to get gunged up).
The former is fixed by no one caring about weight anymore, whats a few grams of outer when you've got 30kg of batteries to lug around. :)
I quite like having adjuster under the down tube on the road bikes, it makes sneaky little on the fly adjustments so much easier, but the winter bike is going fully clad this week I think as the cable guide under the BB gets really nasty this time of year.
Am digging those, could even do a bit of colour contrasting with that.
I’ve used these to route my Magura rim brakes. I have to say, they’re not great, yeah the do colour but as soon as I’m done riding it’s lifted up and let the cable loose again. I actually tightened one so much that I stripped the thread.
Go on vintagecannondale.com and check out the shop. They have some top tube cable guides that just bolt on they’re expensive though and are in the us, so wouldn’t go for that.
I’ve seen some aluminium riveted on cable guides that you could drill through and make so that you could fit a whole cable in.
But…. You can take an easy way and get some tiny cable outers that fit between the cable stops. Like a little hose without metal reinforcement.
But yeah, if you’ve got full cable housing then the only way dirt can get in is the opening on the brakes or derailleur barrel adjusters. Lots of road bikes do it with down tube shifters and internally route on the top tube to the rear brake and just fully route to the front. With downtube shifters you’ve got no cable other than the loop at the rear derailleur. Which I think is a bonus, because if you wash your bike every ride(like I do😉) then if there is no tube to trap dirt, it just washes off before it gets the chance to rust. It also saves weight.
