Well...things are never as simple as you think.  Sometimes its the simplest of things that get complicated
Having got the bars, stem, levers, shifters, grips and ends all out, we realised that the Azonic bars do not have enough grip area.  They are of the STI generation, where much less flat is needed.....arse!
Problem is that its not as simple as changing out the bars for another set of risers, as most won't fit though a closed loop quill stem....  We really wanted some nitto bars for this project, either a801 or a802, but neither are now available in the uk. That would answer all problems as they are designed to twist through quill stems and have 50mm of rise and long long control flat areas.
But at the moment, we either we go back to straighter bars with the loooooong quil nitto riser stem...see photo (as the marin ones run out of height way before flat bars), or we try another solution. Im really not sure we are up for that styling anyway.....i know its a practical bike....but...!
One answer would be to use a quill stem converter (22.2 to 25.4) and then add a 35o ahead stem.  This would allow us to use any bars we like as the stem would be open face, but it wont solve the issue of limited control area.  Even orange supercross have only 7" of flat......
Still going to need some bars with good rise and some good width.....kinda 680 min.
Hummmm.
