Hi everyone, I thought I'd quickly fit a set of SKS Raceblade Long mudguards this evening. It has not worked.
Both guards are easily centred over the tyre but there isn't quite as much adjustability in the stays as I'd thought there would be - so I'm left with quite unsightly gaps around the wheels.
More concerning though is that with the mudguard fitted, neither brake caliper will retract. The guard isn't impeding the brakes as far as I can see. (Bars and levers were removed for cleaning, new cables etc).
I hope the answer is obvious and easy, but what have I done wrong!? Do I need to cut the stays? Is the brake caliper incompatible with a mudguard?
