Mickeyspinn
rBotM Winner
		I forgot all about this!
^should be a 91 outpost
^dunno what year! But it's a steel aggressor.
^should be a 91/92 timberline.
I'll do a load more tomorrow
All sounds good!Thank you! All three of those give me new information and help with details from the frame numbers.
In return, information that may be of interest:
Outpost - This is a 1992, as they used Inferno Red for the Outpost that year, after using it for the Karakoram the year before. This is the earliest frame I have recorded so far built in Taiwan (Hodaka) rather than Japan (Toyo). That makes sense as it seems to have been a gradual move starting with the lower models. I'm fairly confident it was made in January 1992.
Aggressor - the frame was made in 1994, so is either a 1994 (first year for the Aggressor) or 1995 model. The alternative colour option in 1994 was Baja Blue, so that could be it, although the blue in your photo looks a little darker. I haven't seen a comprehensive 1995 catalogue yet, so I'm not sure whether there was a blue option that year for the Aggressor. I have found any definite evidence that there was.
Timberline - 1992 model, frame made March '92. The model code confirms it is a Timberline frame, if it doesn't have decals.
 ^and another 92 timberline!
This is awesome, thank you. Both those Timberlines made January 1992. I assume the previous Timberline had the paint stripped. Was it the same colour as these originally or Daktari White?All sounds good!
There's more
^should be another 92 timberline!
View attachment 665055^and another 92 timberline!
^talera...hmmm 93/94?
I'lll do another load later
This is awesome....I snap a pic you give me infoThis is awesome, thank you. Both those Timberlines made January 1992. I assume the previous Timberline had the paint stripped. Was it the same colour as these originally or Daktari White?
The Talera is a 1993 model, frame made late 1992 at the Hodaka factory.
It's like an off-white kinda pearlescent colour....groove tube aswell!Is the paint original? The frame number would suggest it was made late 1992, if that second digit is a 2. However, the colour options for 1993 were Rainforest Green or Pearl Mist (blue/purple and black).
No black paint drips on it though? (Daktari White?) That was a paint scheme for 1992, but it seems like the frame was built too late for a 1992 model. Definitely made in 1992, which was the first year of the Groove Tube.It's like an off-white kinda pearlescent colour....groove tube aswell!
Second digit does look like a 2...just checked defo H2H0 !
Nope! Just a plain colour way ,it's got the later cheap looking rear dropout like that talera up there ^No black paint drips on it though? (Daktari White?) That was a paint scheme for 1992, but it seems like the frame was built too late for a 1992 model. Definitely made in 1992, which was the first year of the Groove Tube.
