Wartime Peugeot.
Crikey. Some of these bikes are incredibly sublime. I can't even image the cost for some of these back then.
Do you not get the impression that the high end stuff really pushes the envelope - it must have been extremely competitive amongst the smaller builders.
Yeah....kinda bikes if you don't second glance them you miss out! Details to the max and such varied little techniques...I'm starting to think the french were the masters.
Think they would have been very expensive, months of wages for the common man. I think the desire to build the best breeds competition. I have the bill of sale (somewhere safe:rolleyes:) for my Great Grandfathers Chater Lea tandem in the 20's, from memory around 28 Guineas, wages were £2 pw ish.
When I was pulling to bits my own barn finds, I came across this. It's a tiny oil port / grease nipple that was in the bottom bracket shell.
The vernier calliper is set to 5 mm for scale. That little top opens and closes with a wonderful crisp click action, no slop at all. The top is stamped with the manufacturer name and the B TE SDGD is just an incredible extra step - this is watch making type precision. When you consider it's +100 years old too it actually freaked me out the lengths and trouble gone to for such an inconspicuous part that gets gunked up.
Built to last,built to be serviced and built with pride.
I bet it has a tiny bit of felt or a gauze filter in too!?
  • Like
Reactions: Woz
Didn't notice any, it was blocked with old grease when cleaned it out.
On the inside the upper part as a thin wall, then it tapers down to the smaller internal diameter where the thread is.
Had to butcher a 6mm spanner from my electronics repair kit to get the damn thing off - it's 6.5mm - which of course everyone has :mad: o_O
Is it an oiler or a grease port?
Errrr - is there a difference?
It's a whickle fingy with a hole through it, needs a bugger size spanner, and a vwery whickle door on top to stop shite going in.
Have I got my technical terminology in order? ;) It's 2 mins to 19:00 here, so can we use the word nipple now?
