My diamondback sorrento 19?? (Kazakhstan)
Yerassyl Nurmakhan
Всем Привет из KЗ!Мне достался велосипед Diamond Sorrento.жаль незнаю какого года(((
хочу восстановить велосипед)
1-Поставить 29 колеса
2-Кассетную звезду на 10sp.
3-Поменять Вилку(carbon)
4-Тонкие покрыжки
5-Поменять систему Тормозов (V-Brake) на Гидравлическую Систему Тормозов)))
6-Покраска Рамы в цвет Хаки,(Глянець или Матовый)
7-Поменять Шатуны
8-Поменять Руль
9-Педали
10-Сделать из него Городской Велосипед,,,
Что об этом думаете))???
Как Вам идея???)))
Всем Спасибо))))
Here’s the translation from Google.
Hello everyone from KZ! I got a Diamond Sorrento bike. I'm sorry I don't know what year(((
I want to restore the bike)
1-Put 29 wheels
2-Castet star on 10sp.
3-Change The Plug(carbon)
4-thin tires
5-Change the Brake System (V-Brake) to Hydraulic Brake System)))
6-Painting Frame in Khaki colour, (Gloss or Matte)
7-Change Connecting Rods
8-Change The Steering Wheel
9-Pedals
10-Make a City Bike out of it,,
What do you think about it))???
What do you think of the idea???)))
Thank You All))))
Hello! That’s a lot of changes you’re planning. Adding an extra three inches of wheel maybe tricky for frame clearances. If you take a look with the current 26 inch wheels does it look like there would be room for 29ers? As for switching in for hydraulic brakes, you could go with magura rim brakes which would swap in onto the cantilever brake posts, but I rather think you’re interested in adding disc brakes. This is possible with welding. There’s examples in this forum and the web of folks adding discs mounts to retro frames at back and of course some suspension forks come with the mount tabs in you can find something to fit the head tube. Adding a 10 speed ‘star’ (cassette)? may also be tricky owing to the width of the rear wheel spacing. Again the web has examples of making retro hubs take 8 or even 9 speed. Changing out the steering (handle bars) is easy if you find the correct diameter bar for your currrent stem. Once you start changing stems it becomes more complex. In summary anything is possible with work but may not be worth it. Maybe start with adding lower volume tyres and wider bars. All the best! I’m sure everyone is curious what items 3 and 7 are :)
1-Put 29 wheels
4-thin tires
9-Pedals
Thank You All))))
Оууу)))Спасибо за Советы и Комментарии))) (Я Ценю) Даа,Вы правы «может быть дело того не стоит»
В первую очередь это для себя (для души)
2 хотелось дать 2 жизнь велосипеду
Что интересно я сегодня примерил 29 колесо с 10Sp,Что на радость они вмещаются без усилий))))Но возникла проблема с Покрышками (29*2,25) он перестал вмещаться и теперь надо будет искать маленькую покрышку(но пока незнаю с размерами)
Насчёт тормоза гидравлики,поискав в AliExpress)))Я нашёл адаптеры для Гидравлического тормоза)))
Пункт;
3- Передняя Звезда )))
7-Вилка))))
8605CDD0-93EE-44A8-BC85-D55ED7AA593A.webp 03FF227E-20E3-4EAD-AA20-5C98982B1E39.webp 50CFCC6F-6888-4A85-8FE1-64A57122C41B.webp
