Something to rideWhat size wheel? And
are you after a build project or something rideable right away?
I’ll have aaround
Thanks - unfortunately I can’t do much as I’m not a memberThey’re solid frames, forks are naff and seize up, the later model had cranks with two pedal lengths. Other kids bike to look for are the kona hula 24.
Seems to me that looking for frog and hoys people tend to expect to get silly money for them second hand. The treks and kona’s (add vitus to that list) can be picked up for reasonable money.
That’s wiggle/crc on eBay. My son has the twenty inch version and I think they’re great. No cheap, clunky suspension either. Kenda small block, tektro v’s, and you can upgrade the bits easily if you need to save a bit of weight. Rrp £329Thanks - unfortunately I can’t do much as I’m not a member
Just checked and he’s in Windsor so not too far.
You mentioned vitus and I saw this
https://www.ebay.co.uk/itm/18547452...a99DENgT8C&var=&widget_ver=artemis&media=COPYWhat do you reckon?
Thanks for the info!! I’m watching th auctionThat’s wiggle/crc on eBay. My son has the twenty inch version and I think they’re great. No cheap, clunky suspension either. Kenda small block, tektro v’s, and you can upgrade the bits easily if you need to save a bit of weight. Rrp £329
Specs here https://vitusbikes.com/products/vitus-24-kids-bike
And actually we’ve got the sixteen as well awaiting that magical no stabilisers moment for child 2. Haha
