For Sale Klein Adept 1993 23” Drop bar
bat40a6
A unique Jon Rock re-spray in horizon linear fade. This has a quill adapter and shim to run a standard stem with a drop handlebar. I don’t have the MC1 stem anymore.
The frame is in good condition, some mild chainsuck damage, a few chips and bubbles in the paint, the usual stuff. Rear brake cable exit is not drilled and is using an adapter to enable the use of mini v brakes. A dent in the top tube was repaired before the re-spray. All bearings are smooth.
Parts are:
Ultegra 10 speed shifters
Campagnolo 175 mm crank with Absolute Black 42T chainring
Shimano XT rear derailleur
TRP mini v brakes
Fulcrum wheels with Vittoria 32mm Terreno tyres
Shannon post
FSA alloy bars
Thomson 100mm stem
Fizik Arione saddle
Shimano SPD pedals
This is a big bike and fits me at 6’1”. You need to be 6 foot plus to fit it.
Geometry for the frame can be found here
https://www.retrobike.co.uk/gallery2/d/2625-2/Klein1993.pdf
I am looking for a UK sale at the moment. I am based in Bristol but regularly travelling to the south east if that helps. Asking £2000.
