Univega ram 900 1999
Siish
Muddy Fox Fan
This is my latest build, a 1999 univega ram. It is a 1x 9 speed, SRAM x9 rear derailleur with a SRAM x7 shifter, suntour crank set with a 38t narrow wide chain ring, rock shox sid rear shock with manitou Magnum r front forks, 70mm 35° stem angle, with hydraulic disc brakes. Thanks to @legrandefromage for providing the frame and helping with the build
Hi, I have exactly the same frame. I'm looking at upgrading the rear shock. Think it's 165mm eye to eye but can't be sure. Are you able to advise on the eye to eye of your shock? Thanks in advance.
