Hi and heads up for the nice build idea!
The Dkg are made for the first two Generations of XT Trigger shifters,
If you really want to use the Xtr Shifters keep searching for wtb multimount perches.
Otherwise Multimounts can be also made to work with early generation Suntour shifters.. but there is a baseplate modification needed unless you use the LD-2800.
WTBs even earlier sausage links (adapter plates) for suntour towers in use with their friction shifters can be easily reproduced.
More info here:
Thank you for the info and the link, some lovely pics on there
I was planning to use XT m735 triggers for now and was hoping to jump to XTR once I get an appropriate wheelset with 8 speed hub. I was under the impression that these DKG's could be used with m900 shifter pods, is that wrong?
These suntour shifters are lovely I really like the ratchet action and overall look and feel of them, and I've always been more of a thumbie lover than a trigger man anyway, so I'm starting to lean towards the suntours as a permanent fixture, I say that having the m900's ready to go, but if it's going to cost me £300 or whatever to be able to use them well I'm not that crazy about them.
So I guess what I'm wondering is with the new band clamps will there be a way of mounting the suntours that will make them practically accessible? ie not on the top of the bars? And if I manage to find a tower/nut that is compatible with the DKG's what steps would I need to take to fit the suntours?
if they have the same nut but with a smaller hole (4mm) then they may be the answer to that particular issue.I have some suntour command shifters?
In the mean time I've deep cleaned the XT canti's
Before...
After...
