WANTED - Triple Butted Kona Project 2 Threaded
Alex3795
Hi,
I'm beginning the process of restoring a 94 Explosif. Although I have the origional shocks I'd also like to have the option of running a rigid forks.
Hence I am after a pair of Project 2s, Triple Butted with threaded 1 1/8th steerer, min length 145mm.
Also after a few of other bits inc:
XT rear mech - M739 8 speed
XT rear cassette 11-28 8 speed
Shimano SG-X chain rings - 110BCD
O-Beam decals
Many thanks,
Alex
I’ve got some P2 forks listed on here but no idea if TB.
They usually have TB stamped into the steerer if I am not mistaken.
I think I have some, but will need to check. Any idea what length you require? I think mine are 425mm c - a.
Yep, they should show TB (along with CR) if they are triple butted
If you have any photos you could post that would be great
Many thanks
https://www.retrobike.co.uk/threads/kona-project-2-fork-threaded-£50.439132/
This is all I have until I’m home. Doubt they are TB though
Based on the decals they are triple butted but I think the condition isn't quite what I'm after.
Sure they could be fine but it's hard to tell the extent of rust from photos
Thanks all the same though
Just checked and yes they have TB stamped on mine. The corrosion is surface only.
I’ve also get this to split but doubt they TB on a lava dome
