jorgemrnh
Hi guys,
||||||||||| S P E C S |||||||||||
Frame - Specialized Stumpjumper FS 1995
Fork - Rockshox Mag21
Headset - Dia-Compe Kontak Aheadset ST 1 1/8"
Stem - Specialized cold-forged alloy Aheadset
Handlebar - Specialized Alloy 170g
Grips - ???
Barends - ???
Brakes - Shimano Dia-Compe PC-7 levers
Brake Pads - ???
Brake Cables - ???
Cantilever cable hangers - ???
Brake Levers - Shimano Deore LX M-System
Shifters - Grip Shift SRT-800 X-Ray
Front Derailleur - Shimano Deore LX Compact Drive, bottom-pull/clamp-on 31.8 mm
Rear Derailleur - Shimano Deore XT RD-M737 GS
Derailleur Cables - ???
Cassette - ???
Chain - ???
Cranks - Shimano Deore LX HyperDrive-C
Crank Bolts - ???
Chainrings - Shimano 24/32/42
Chainring bolts - ???
Bottom Bracket - ???
Pedals - ???
Hub Skewers - ???
Rims - Specialized Z-21 32h 26''
Hubs - ???
Nipples - ???
Spokes - Wheelsmith stainless steel, 2.0 mm SP
Tyres - ???
Tubes - ???
Saddle - Specialized Prolong
Seatpost - Tahima 30,4mm
Seatpost Binder - Specialized
Weight - N/D
||||||||||| STORY |||||||||||
So i bought this bike from a family member that was using it for the usual commute until i saw it and fell in love
He bought it in Switzerland from a canadian professor that originally bought it in a store called Spoke 'N Edge (Canadian Rockies), so i'm the third owner.
He had no idea of what he had. The bicycle was all around well maintained and i want to restore it and after that give it a bit of upgrade with maybe purple bits to match the frame accents. I work in the bicycle graphics design area so i will also create a graphics sticker kit for it as some of them are damaged.
Took it all apart, cleaned it and i want to bring it back to the old glory but as i'm a newbie i need some help to find the right parts and give some of the originals a better look if you guys don't mind. I love engineering, i love the history being things, and above all, i love to ride these beasts. Like in a classic car, there's nothing as a sunday chill ride in a raw machine like this.
||||||||||| NEED HELP |||||||||||
- Found some rust spots, and the area inside the bottom bracket and seat tube, has a bit of rust. Is there a product so we can like fill the frame with that will remove and protect the frame against any future rust? On the outside i was thinking maybe correct the little spots and give it a new layer of clearcoat.
- About the fork, i was able to pump it up a bit, but it definately needs a service. Anyone has some doc's about it?
- The gripships, the rubber itself, it's in a rough shape. Is there anyone that knows how to find some replacement? And also grips, the original s-works, were all damaged.
- I've tried to polish the bar so the damages would dissapear, but without any good result unfortunately. Anyon can give me a tip of how to bring back the polished look? I would love to do the same to the seatpost and crankset.
Thank you guys!
Cheers!
Grips - ???
Barends - ???
Brake Pads - ???
Brake Cables - ???
Cassette - ???
Chain - ???
Crank Bolts - ???
Pedals - ???
Hub Skewers - ???
Hubs - ???
Nipples - ???
Tyres - ???
Tubes - ???
Weight - N/D
||||||||||| STORY |||||||||||
Thank you guys!
Cheers!
