Syncros Crank-o-matic
MR OX
Specialized Fan
I've been after one of these for a while however have only managed to find one that was a little bit more damaged than I was prepared to go for at just under £25, I've seen sets up for bonkers money so when I spotted these on Ebay at £30 Thursday night I thought they didn't look too bad AAA.webp AAAA.webp
They arrived today, so I gave them a good spray with graffiti remover (I don't have any paint stripper at home) then went at them with a cloth, small plastic scrapper & a pin. Really pleased with how they turned out, only took about twenty minutes. AAAAAAA (2).webp
Remember to use steel bolts first to tighten up the cranks properly, remove them, then fit these. £30 is a v good price, seen them go for a lot more too.
I thought that was only relevant when using aluminium bolts??
Always did same with Ti bolts, as they can be soft when torqued up hard. Allen ones are even more prone to getting stretched. Its only relevant if its gonna be ridden properly like bitd 🤔
It's in the instructions I linked too ;-)
If they've not been used together before (crank and bb) then use steel bolts to make them mate i.e. basically mould the crank taper.
Crank O matic Allen key is smaller than normal and they, as I think you can see in the picture a bit on the left one, dint much easier.
You often see them with slip marks.
