You need to see if the seat pin is free - so you can adjust to suit your body.
Same applies to the stem.
I would be tempted to check these two ahead of going to a LBS, however I do think a LBS is a better bet than a big chain like Evans or Decatholon.
Your best bet of all would be a bike charity place that allows you to work on your own there - as to restore something like this you will hit a lot of little problems that even a friendly LBS will have to charge you a lot for.
Also I doubt your rear width is 130mm, possibly 126 or 120??
Your hubs look nice with a deep flange - you could look to rebuild them with new spokes and rim - but this will cost.
