Hi there,Have a pair of silver Controltech bars,they're 540mm.Don't know if they've been cut?Was going to fit bar ends on extenders but found some 560mm alternatives.Mint condition,logos perfect,no scratches.Also have some pretty good M737 combos in the garage,will dig them out.From memory they're good cosmetically and haven't seen much use.
Hi Will.Not At home currently,did quickly check before I left.They’re a bit dusty but look good,not particularly marked/scratched.The 8 speed shifter is doing the typical sticking.If you can wait till Tuesday I’ll give them a clean up and make sure they’re fully operational before I let them go.Price will be fair n reasonable![]()
Great , Tuesdays good for me ,Hi Will.Not At home currently,did quickly check before I left.They’re a bit dusty but look good,not particularly marked/scratched.The 8 speed shifter is doing the typical sticking.If you can wait till Tuesday I’ll give them a clean up and make sure they’re fully operational before I let them go.Price will be fair n reasonable![]()
