Update Dec-24
Pip is currently enjoying the great universal single-track. He had a great send-off which you can read about here: https://www.retrobike.co.uk/threads/phillip-pipmeister-mock-kona-guru-and-legend.443234/
His friendship is the greatest legacy he leaves us with but we must not forget the incredible resources and knowledge that he documented locally and shared here on retrobike, not least the Kona serial numbers and related information.
I continue to administer the work he started and spend an hour a week updating the lists with any new entries or confirmed related data / information. The same criteria applies as before, so if you'd like to have your Kona Hot added to the list, please follow these steps before PMing with your details or questions:
1. Must be a Kona Hot
2. Have an eligible serial number, found on the bottom of the bottom bracket
3. Provide photographic evidence, preferably as the current owner
4. Check the bike and serial number isn't already on the current list (note if the record was unconfirmed previously, new details are welcome)
I create a weekly Instagram post with highlights of newly or recently identified frames from the Kona custom program. If you are on the platform and are happy to be tagged, please share your username. Alternatively, if you would prefer not to have your bike featured please let me know when you share the details here.
Big thanks to John for helping configure this and as ever - a huge thank you - to all current and past Kona-heads including Pip. Without our collective knowledge, none of this would be possible
To make finding the lists and associated data a little easier, this first post will contain the master data.
Don't forget the other registers!
Kona Titanium frames & bikes: https://www.retrobike.co.uk/threads/kona-titanium-serial-number-list-update-08-06-23.464733/
Kona Caldera: https://www.retrobike.co.uk/threads/kona-caldera-serial-number-list-update-june-2022.446749/
Kona Ku: https://www.retrobike.co.uk/threads/kona-ku-serial-number-list-update-june-2022.446754/
So without further ado...
____________________________________________________________________________________________
Red - confirmed with picture, Blue - good source, but TBC, Black - only quoting from forum post or advert.
Kona Hot Frame Serial Numbers:
1991-1995 Tom Teesdale: West Branch, Iowa, Idaho.
The 1991 – 1995 frames are made from various mixes of Tange Prestige Concept, Tange Ultimate / Ultrastrong, Tange Ultimate / Superlight and Tange Ultimate / Ultralight.
Dropouts from ’91 – ‘93 with triangle hole.
Dropouts from '94 & ’95 have no triangle hole.
Serial Number format: TET# - TET####.
1996 & 1997 Altitude Cycle Technologies: Chico. California.
The 1996 & 1997 frames are made from Reynolds 853 Butted Main Tubes, and rumoured to have 725 Stays.
Update Oct-25 (al-onestare)
1997 dealer spec sheet quotes as "made entirely of Reynolds 853 tubing", which is contrary to the 853 decals that state main tubes only.
Dropouts on some early 1996 Altitude Hot frames have a similar flat design to the later TET frames - these frames have one Rear Brake Cable Stop at the front of the Top Tube & require a Dog Collar, with Down Tube routing for the Front and Rear Mech.
The later 1996 Hot frames have Goathead Investment Cast Dropouts – these frames have two Rear Brake Cable Stops on the Top Tube, with Down Tube routing for Front and Rear Mech.
Serial Number format 1996 frames - HT### & HT0### (currently with one exception).
The 1997 frames also have Goathead Investment Cast Dropouts, but with two double Cable Stops on the Top Tube at the front and the rear for the Front Mech and Rear Brake, with Down Tube routing for the Rear Mech.
Serial Number format 1997 frames - H096MM###.
1998 Enigma Design & Manufacturing: U.S.A. & Hodaka: Taiwan (built in ‘99).
The 1998 Enigma Hots are allegedly manufactured entirely from 853 Reynold tubing including the Stays. They have an Opposite Oval Downtube and lack the Bridge across the Chain Stays, similar to all Kona Ku frames.
Dropouts are the New (Dew) Drop Investment Cast “K” style.
Serial Number format: KH7M### & KH8M###.
The 1998 Hodaka built Hot rolled over into 1999. They have Rack Eyelets on the Seat Stays, and a Chain Stay Bridge. These also have the Opposite Oval Downtube, and may be all 853 tubing similar to the Enigma built Hot.
Dropouts are the New Drop Investment Cast “K” style.
Serial Number format: H9N1 ###.
Tom Teesdale:
TET 18 - 19” 1991 Orange, resprayed same colour c/w extra Rear Brake Stop – Integral Welded Seat Post Clamp, Integral under B.B. Cable guide, Triangle cut-out Dropout. (also stamped- 90KH0827C).
TET 18 - No picture of entire frame to establish size, 1991 Orange, Integral under B.B. Cable guide. Also stamped - 90KH0827D, with only the letter "D" making it unique.
TET 040 – 19” 1991 Red - Integral Welded Seat Post Clamp, Triangle cut-out Dropout.
TET 060 - 19" 1991 Red/dark Orange - Integral Welded Seat Post Clamp. Triangle cut-out Dropout. On display at Bellingham warehouse.
TET 066 - 19” 1991 repainted Purple by Peter Weigle c/w Custom Rear Brake Noodle (requested by Kona Grassroots Racing program member), No Decals - Integral Welded Seat Post Clamp - Triangle cut-out Dropout.
TET 095 - 16” 1991 Purple / White fade - Integral Welded Seat Post Clamp, Triangle cut-out Dropout.
TET 097 – 16” 1991 Blue - Integral Welded Seat Post Clamp, Triangle cut-out Dropout.
TET 102 – 16” 1991 Silver - Integral Welded Seat Post Clamp, Triangle cut-out Dropout.
TET 107 - 16” 1991 Purple - Integral Welded Seat Post Clamp, Triangle cut-out Dropout.
TET 112 - 19" 1991 Red - Integral Welded Seat Post Clamp, Triangle cut-out Dropout.
TET 142 – 19” 1991 Steel Blue - Integral Welded Seat Post Clamp, Triangle cut-out Dropout.
TET 153 - 19" 1991 Black - Integral Welded Seat Post Clamp, Triangle cut-out Dropout. Seat-stay U-brake mounts.
TET 171 - 19” 1992 Steel Blue - Triangle cut-out Dropout.
TET 175 - 19” 1992 Black - Triangle cut-out Dropout.
TET 181 - 21” 1992 Blue – Dropouts out of shot.
TET 182 - 21" 1992 Blue - Dropouts out of shot.
TET 216 - 17" 1993 Green/grey to forest green fade - Triangle cut-out Drop Out.
TET 222 - 16” 1993 Yellow - Triangle cut-out Dropout.
TET 251 - 19” 1993 Dark Metallic Blue - Triangle cut-out Dropout.
TET 253 - 19” 1993 White stays / Black front triangle - Triangle cut-out Dropout.
TET 262 - 19” 1993 Silver Lilac tint - Triangle cut-out Dropout.
TET 270 - 19” 1993 Reddish/Orange - Triangle cut-out Dropout.
TET 295 - 18" 1993 Mint green - Triangle cut-out Dropout.
TET 307 - 18” 1993 Metallic Purple - Triangle cut-out Dropout.
TET 314 - 19" 1993 Blue to Champagne fade - Triangle cut-out Dropout.
TET 330 - 21" 1993 Bronze to Purple fade - Triangle cut-out Dropout. Tange Ultrastrong Ribbed DownTube. Original complete 1993 decals.
TET 336 - 21” 1993 Metallic Green - Triangle cut-out Dropout.
TET 338 - 21” 1993 Originally Dark Blue, now Apple Green - Triangle cut-out Dropout.
TET 350 – 19” 1993 Red - Triangle cut-out Dropout.
TET 360 - 19” 1993 Purple c/w 1994 Decals - Triangle cut-out Dropout.
TET 364 - 19” 1993 Burgundy c/w 1992 Decals, now Raw - Triangle cut-out Dropout.
TET 366 - 21" 1993 Original colour unknown, now Candy Apple Green, 1993 reproduction decals - Triangle cut-out Dropout. No picture of SN.
TET 367 - 19” 1993 Dark Green c/w custom U-Brake - Triangle cut-out Dropout.
TET 377 - 18” 1993 Originally Purple/Blue, now Yellow c/w ‘94 Headtube Decal & remainder ‘96 Decals - Triangle cut-out Dropout.
TET 408 - 19” 1993 Red/ Black fade - Triangle cut-out Dropout.
TET 420 – 19” 1993 Metallic Grey by Chris Dekerf c/w rear rack mounts, No Decals - Triangle cut-out Dropout.
TET 422 - 20” 1993 Burgundy/Black fade - Triangle cut-out Dropout. Complete Original Decals.
TET 431 – 16” 1993 Green to Gold fade - Triangle cut-out Dropout.
TET 465 - 18” 1993 Silver / Purple fade, now Aqua or Mint - Triangle cut-out Dropout.
TET 472 – 19” 1993 Deep Aqua Blue - Triangle cut-out Dropout.
TET 488 - 19” 1993 Porsche Red – Triangle cut-out Dropouts.
TET 490 - 19” 1993 Originally Burgundy, now stripped - Triangle cut-out Dropout.
TET 526 - 19” 1993 Blue - Triangle cut-out Dropout.
TET 528 - 19” 1993 Green - Triangle cut-out Dropout
TET 535 - 17” 1993 original colour unknown, repainted Yellow - No Decals – Triangle cut-out Dropout.
TET 549 - 18" 1993 Grey - Triangle cut-out Dropout. Tange Ultrastrong Ribbed DownTube. Original Decals. No picture of SN.
TET 550 - 17” 1993 Apple Green - Triangle cut-out Dropout.
TET 551 - 17” 1993 Apple Green - Triangle cut-out Dropout.
TET 555 - 21" 1993 Dark blue - Triangle cut-out Dropout. Broken Tange Ultrastrong Ribbed Downtube. After-market disc tab. Original head-tube decal, rest unknown.
TET 575 - 14" 1993 Metallic Cherry Red fade (possible natural colour fading) - Triangle cut-out Dropout.
TET 576 - 16” 1993 Green - Triangle cut-out Dropout.
TET 591 - 19” 1993 Orange c/w 94 Decals & Post Mount type Disc Tab, (possibly for Factory Team bike) - Triangle cut-out Dropout.
TET 593 - 19” 1993 Purple / Green fade, (possibly Team frame) - Triangle cut-out Dropout.
TET 609 - 21" 1993 Black / Blue fade (possibly aftermarket) - Triangle cut-out Dropout. States SN ends with "C".
TET 635 - 18" 1993 Metallic Purple - Triangle cut-out Dropout. 3 may be 8.
TET 640 - 19” 1993 Purple - Triangle cut-out Dropout.
TET 670 - 18" 1993 Metallic Blue (unclear if original paint) - Triangle cut-out Dropout. No Decals.
TET 687 - 18” 1993 Grey - Triangle cut-out Dropout.
TET 695 - 21" 1993 Metallic Purple - Triangle cut-out Dropout. Original decals. No picture of SN.
TET 725 - 19" 1993 Grey? (resprayed) - Triangle cut-out Dropout. No original decals, re-badged as a Rock Lobster.
TET 769 - 18” 1993 Black, Tange Ultimate Ultrastrong Decal only (allegedly Max Jones Team Bike) -Triangle cut-out Dropout.
TET 787 - 18” 1993 repainted Orange c/w ’94 Decals & I.S. Disc Tab - Triangle cut-out Dropout.
TET 798 - 16” 1993 Sliver - Triangle cut-out Dropout.
TET 799 - 16" 1993 Orange frame with turquoise top tube pattern, green "cactus arms" design seat tube, white (or faded paint) undercarriage. Triangle cut-out Dropout. Original decals. Tange Ultrastrong Ribbed Downtube.
TET 822 - 17” 1993 original colour unknown, repainted Lemon Yellow, No Decals - Triangle cut-out Dropout.
TET 853 - 20” 1993 Champagne - Triangle cut-out Dropout. Tom Teesdale’s!
TET 877 - 18" 1993 Metallic Purple/Pink - Triangle cut-out Dropout. Original Decals (missing Hot decal).
TET 907 – 16” 1993 Original colour unknown, now Mustard, No Decals - Triangle cut-out Dropout.
TET 910 - 16” 1993 Purple c/w 1994 Silver/Orange Headtube Spiral Decal, and Silver Top Tube & Down Tube Decals, but also c/w 1995 “KONA Custom” Italic Decal – Triangle cut-out Dropout.
TET 924 - 14” 1993 Metallic Blue - Triangle cut-out Dropout.
TET 930 - 20” 1993 Dark Green - Triangle cut-out Dropout.
TET 966 - 19” 1993 Originally Burgundy front / repainted Orange Stays, now Raw Steel - Triangle cut-out Dropout.
TET 980 - 19" 1993 Metallic Turquoise - Triangle cut-out Dropout. Tange Ultrastrong Ribbed Downtube. Original Decals, missing Hot Decal.
TET 1008 - 19" 1993 Light Metallic Blue - Triangle cut-out Dropout. Original Decals.
TET 1010 - 19” 1993 Purple/Pink - Triangle cut-out Dropout.
TET 1015 - 19” 1993 Purple - Triangle cut-out Dropout.
TET 1036 - 18" 1993 Green/purple - Triangle cut-out Dropout. Original head-tube decal only. Green tubes with fade to purple on drop-outs, BB, seat-post clamp and head-tube
TET 1065 - 19" 1993 White c/w 1994 Decals - Triangle cut-out Dropout. Race-team bike on display at Bellingham warehouse. Canadian flag seat-tube decal.
TET 1079 - 18" 1993 White c/w 1994 Decals - Triangle cut-out Dropout (previously incorrectly recorded 1078 )
TET 1106 - 18” 1993 Aqua Green - Triangle cut-out Dropout.
TET 1111 - 18" 1993 Pearl Silver - Triangle cut-out Dropout. Tange Ultimate Ultrastrong Downtube Decal, missing top-tube and down-tube decals.
TET 1122 – 14” 1993 Teal Green c/w 1994 Decals - Triangle cut-out Dropout.
TET 1167 - 20" 1994 Orange, original 1994 Decals - No Triangle cut-out Dropout.
TET 1189 - 20” 1994 Aquamarine Blue – No Triangle cut-out Dropout.
TET 1200 - 14” 1994 Metallic Green – No Triangle cut-out Dropout.
TET 1210 - 16" 1994 Purple - No Trianble cut-out Dropout. Original and complete 1993 decals. Tange Ultrastrong Ribbed Downtube.
TET 1216 - 19” 1994 Champagne Gold – No Triangle cut-out Dropout.
TET 1222 – 17” 1994 Champagne - No Triangle cut-out Dropout.
TET 1225 – 17” 1994 Grey – No Triangle cut-out Dropout.
TET 1245 – 16” 1994 Metallic Green (original colour unknown) all Top Tube cable routing & and Disc Mount added - No Triangle cut-out Dropout.
TET 1260 - 14" 1994 Forest Metallic Green - No triangle cut-out Dropout. Tange Ultrastrong Ribbed Downtube.
TET 1301 - 19" 1994 Cherry Red - No triangle cut-out Dropout. Tange Ultrastrong Ribbed Downtube.
TET 1304 - 19” 1994 Dark Green - No Triangle cut-out Dropout.
TET 1305 - 19” 1994 originally Dark Green, now Raw, Tange Ultimate Utrastrong Downtube - No Triangle cut-out Dropout.
TET 1310 - 18" 1994 originally Silver Grey, now Pastel Blue c/w extra Rear Brake Stop - No Triangle cut-out Dropout.
TET 1322 - 18” 1994 originally Green, now Metallic Blue c/w Custom Cable Guides - No Triangle cut-out Dropout.
TET 1373 - 19” 1994 Aqua Blue, Tange Ultimate Utrastrong Downtube - No Triangle cut-out Dropout.
TET 1392 - 18” 1994 Silver - No Triangle cut-out Dropout.
TET 1398 - 19" 1994 Orange - No Triangle cut-out Dropout. Ribbed Downtube. Reproduction 1994-eqsue downtube decals.
TET 1422 - 18" 1994 Dark Green - SN picture only so unable to confirm other details.
TET 1431C - 22” 1994 Burgundy - Unique Custom sized Seat Tube length, with a shorter Top Tube from Joe Murray’s Geometry - No Triangle Cut-out Dropout.
TET 1450 - 18” 1994 Blue - Top Tube Cable Stop removed! - No Triangle cut-out Dropout.
TET 1463 - 18” 1994 Cobalt Blue c/w Block “Kona Custom” 1994 Decal - No Triangle cut-out Dropout.
TET 1507 - 18” 1994 Tequila Sunrise c/w 1994 Silver/Orange Headtube Spiral Decal, and Silver Top Tube & Down Tube Decals, but also c/w 1995 “KONA Custom” Italic Decal - No Triangle cut-out Dropout.
TET 1517 - 19" 1994 Royal Blue, Silver Decals, No Triangle cut-out Dropout.
TET 1522 - 18" 1994 Royal Blue, Silver Decals c/wo "Kona custom" decal, No Triangle cut-out Dropout.
TET 1530 - 18” 1994 White c/w Block “Kona Custom” 1994 Decal - No Triangle cut-out Dropout.
TET 1548 - 16” 1994 Dark Blue c/w Block “Kona Custom” 1994 Decal - No Triangle cut-out Dropout.
TET 1620 - 18” 1994 Burgundy, No Triangle cut-out Dropout.
TET 1637 - 20” 1994 Yellow to Orange fade (possibly Factory Team bike) - No Triangle cut-out Dropout.
TET 1638 - 20” 1994 Burgundy c/w Gold 1995 Decals including “KONA Custom” Italic 1995 Decal - No Triangle cut-out Dropout.
TET 1645 - 20” 1994 Burgundy c/w Gold 1995 Decals, Kona Custom Decal missing – Picture of Dropouts not clear.
TET 1657 - 17” 1994 Yellow to Orange fade (possibly Factory Team bike), Sliver Decals c/w 1994 Block “Kona Custom” Decal and Factory Team Headtube Decal - No Triangle cut-out Dropout..
TET 1681 - 17” 1994 Orange c/w Gold 1995 Downtube, Toptube & Headtube Decals, Kona Custom Decal missing (allegedly Trish Sinclair Team bike) - No Triangle cut-out Dropout.
TET 1682 – 17” 1994 Burgundy, Silver Decals c/w 1994 Block “Kona Custom” Decal - No Triangle cut-out Dropout.
TET 1705 - 19” 1994 Yellow to Orange fade (possibly Factory Team bike), Silver Decals, Kona Custom Decal missing - No Triangle cut-out Dropout. Now repainted Metallic Orange.
TET 1710 - 19" 1994 Yellow resprayed, reapplied 1994 Headtube and Kona Custom Toptube decals only - No Triangle cut-out Dropout.
TET 1713 – 19” 1994 Creamy Yellow with Custom Cable Guides, Silver Hot and Headtube Decal only, no Kona Custom Decal - No Triangle cut-out
Dropout.
TET 1882 – 14” 1995 Silver Tange Ultimate frame c/w 1996 Blue Decals - No Triangle cut-out Dropout.
Altitude:
HT0104 - 19" 1996 Metallic Turquoise, Goathead Dropouts, Rear Brake Stop. Resprayed around 1998 with period correct decals.
HT0111 – 17” 1996 Burgundy, Goathead Dropouts, Rear Brake Stop.
HT 121 – 19” 1996 Stars ‘n’ Bars, Flat Dropouts, Dog Collar.
HT 123 – 19” 1996 Stars ‘n’ Bars, Flat Dropouts, Dog Collar.
HT0127 – 16” 1996 Stars ‘n’ Bars, Goathead Dropouts, Rear Brake Stop, bought early Spring ‘96.
HT0130 - 20" 1996 Gold (1996 Team Issue Gold / 1997 Explosif Mustard), Goathead Dropouts, Rear Stop.
HT0176 – 17” 1996 Orange (1996 Team Issue Gold), Goathead Dropouts, Rear Brake Stop.
HT0192 – 18” 1996 Stars ‘n’ Bars (possibly ex-Team member’s bike), Goathead Dropouts, Rear Brake Stop.
HT 209 – 18” 1996 Stars ‘n’ Bars Goathead Dropouts, Rear Brake Stop.
HT 218 – 18” 1996 Stars ‘n’ Bars, Goathead Dropouts, Rear Brake Stop. With paint-matched Judy forks.
HT 262 - 17” 1996 Burgundy, Goathead Dropouts, Rear Brake Stop.
HT 264 - 18" 1996 Stars ‘n’ Bars, Goathead Dropouts, Rear Brake Stop.
HT 277 – 20” 1996 Electric Blue, Goathead Dropouts, Rear Brake Stop.
H09606036 - 18” 1996 Burgundy rear half, Orange front half c/w Maple Leaf design, Goathead Dropouts, 1996 Cable Stops – no Decals.
H09607042 - 18" 1997 Metallic red, Goathead Dropouts.
H09607048 – 18” 1997 Rasta Green & Yellow Flame, Goathead Dropouts.
H09607080 - 16" 1997 Red, Goathead Dropouts. Original Decals. Top of seat-tube removed. Holes in drive-side seat-stay.
H09607087 - 16" 1997 Metallic green, Goathead Dropouts. Original decals.
H09611004 - 14” 1997 Stars ‘n’ Bars, Goathead Dropouts.
H09611034 – 19” 1997 c/w ’96 Decals, Blue with Burgundy Flame, Goathead Dropouts.
H09611049 – 18” 1997 Stars ‘n’ Bars, Goathead Dropouts.
H09611059 – 19” 1997 Stars ‘n’ Bars, Goathead Dropouts.
H09611061 – 18” 1997 Rasta Green & Yellow Flame, Goathead Dropouts. Original custom white edged down-tube decals. Standard original head-tube and 853 decals. No custom made seat-tube or top-tube decals.
H09611102 – 19” 1997 Rasta Green & Yellow Flame, Goathead Dropouts.
H09611108 - 18" 1997 Stars 'n' Bars, Goathead Dropouts.
H09611110 – 17” 1997 Burgundy with White Headtube & Spears, Goathead Dropouts.
Enigma:
KH77017 - 17" 1998 Sparkle Green c/w '95 Decals (original colour Green), Enigma w/o Chain Stay Bridge.
KH77023 - 18” 1998 Purple with Green Flame, Enigma w/o Chain Stay Bridge.
KH78001 - 18" 1998 Sky Blue, Enigma w/o Chain Stay Bridge (sold as frame and parts only)
KH78005 – 18” 1998 Black (then apparently Orange), Enigma w/o Chain Stay Bridge.
KH78006 - 18" 1998 Purple with Green Flame, Enigma, w/o Chain Stay Bridge.
KH78007 – 18” 1998 Stars ‘n’ Bars (sold 27/02/98 on Ferndale receipt), Enigma w/o Chain Stay Bridge.
KH89067 – 19” 1998 Cherry / Purple, no picture of Chain Stay Bridge.
KH89083 – 19” 1998 Metallic Orange, Enigma w/o Chain Stay Bridge.
KHB0118 (possibly KH80118 or KH89118 20” 1998 Mustard Yellow, Enigma w/o Chain Stay Bridge.
Hodaka:
H8A2 5608 - 17” 1998 in 1997 livery with Rasta Green and Yellow Flames, and 1998 Cable Routing – claimed to be a Demo frame. No Opposite Oval Downtube, which is a feature of the Hodaka built Hot – therefore possibly a ‘98 Explosif.
H9N1 7763 – 21” 1998 Green.
H9N1 7857 – 18” 1998 Sparkle Red.
#H9##350 (possibly H9N1 #350) – 18” 1998 Metallic Green.
To Be Continued, Pip...
Tom Teesdale:
Dropout.
Altitude:
Enigma:
Hodaka:
