Manitou2 Rebuild - washer spec advice required
Carge
Orange 🍊 Fan
According to the diagrams on the Manitou2 - there are three washers in the lower leg - 2 between the elastomers - and one up by the bushing. Then there's the rebound washer in the bottom of the stanchion.
Having disassembled two of these - I have a motley collection of washers:-
A few flat 26mm ones that I presume are the inter elastomer ones
One flat 23mm one - that I reckon is the top compression washer.
Then one flanged 21mm one - which was down in the bottom of the leg.
Any RBers familiar with what size washers should be in here - and where.
Thanks in advance
Hey Steve, thanks for that.
So it looks like the flanged one is a reject as far as the Manitou2 goes 👍
I'd seen that PDF - it gives the number of washers - but not the dimensions. The top washer seems smaller so maybe that's the 23mm one - and the 26mm are the lower ones?
I hadn't spotted it before - but SRP sell compression washers :)
