For Sale Kingdom Void Titanium 27.5" 130mm frame, Cane Creek DB Coil
coreygun
Kingdom The VOID 130 Titanium frame & Cane Creek Inline CC coil shock with Valt progressive spring
This was an ex-display frame of theirs, only ridden twice by me since buying it. A great frame but I already have too many bikes including 2 more Kingdoms, I just wanted to try it. It basically looks new, so save yourself a ton of money and huge wait time on a new one! This model has 3D printed frame parts around the BB and swingarm yokes.
I'll leave the internally routed dropper and rear mech cable outers in for you. It does have a Shimano Saint rear brake internally routed, so if you want to buy the F&R set of Saint brakes for £150 I'll leave that set up for you. The frame is 130mm rear wheel travel, (210x50mm shock) but the included shock is 52.5mm stroke giving 137mm travel. There is sufficient clearance to go all the way up to 60mm stroke giving 156mm travel. Rear shock is a Cane Creek Inline coil, pedal lever, with a 500>610lb progressive CC Valt spring, good for rider weight around 70-75kg.
  • Reach: 465-470mm with a 130-140mm Fox 36 fork.
  • Head angle: 65°
  • Seat tube length: 415mm
  • Chain stay length: 438mm
  • Internal cable routing for dropper, gear cable and rear brake hose.
  • Seat tube and clamp: 31.6/34.9mm
  • Boost rear axle: 12x148mm
  • Standard derailleur hanger
£2200 Frame & shock, £1950 Frame only, Collected from Surrey. I'd much prefer collection due to it's value, but I can post it with ParcelForce 48 - it will 100% have to be insured though which is why it will cost you £80 (it'll cost a lot more but i'll chip in). PayPal fees will be extra too.
Available on Ebay too.
More Void photos...
I do not need a new frame to match my vendetta 22 hardtail. I do not need a new frame to match my vendetta 22 hardtail. I do not need a new frame to match my vendetta 22 hardtail. I do not need a new frame to match my vendetta 22 hardtail...
