MSYT
OK so I've dug out a few more bits from the garage to clear some space and get something for the old pizza fund. I'll try to price things low but if I'm out still, give me a shout
Saddle bag support - Simple design, I haven't touched this in terms of cleaning it up so it's still got all the surface corrosion but the worst parts are around the clamp - £10 posted
GB Stem - 22.2mm Quill by 145mm total length by 50mm reach. For 25.4mm bars. Pretty clean actually but could always benefit from a polish. £10 posted
GB Superhood Brake Levers - Basically for spares - No clamps, one adjuster is good, the other's cable stop part has broken away £10 posted
Phillips Pedals - 4" x 2 1/4" ish. Both feel well greased but there is a small bit of play in the axles. Lets call the chrome condition worn... or... patina. £10 posted
Cyclo Benelux 3 Speed Derailleur & Shifter - Well the shifter isn't stamped Cyclo anyway but it looks similar. The clamp has missing chrome. The derailleur really really needs to be stripped down and serviced. The cage swings forward and springs back nicely but the chain/lateral movement is very stiff and need a bit of force to move it. Maybe £25 posted
Wing Nuts - Internally I'm measuring about 9mm on the threads. They're steel. They're rusty. £6 posted
Sturmey Archer K Hub - So this will need a full service. I don't have the time or motivation to do it myself. The freehwheel part of the hub rotates and you can hear the clicking internally but it feels very greasy inside so the SA tick is quiet. The brake seems to be seized. I cant move the lever by hand or rotate the shell around it. I can;t thread the indicator spindle back on either. It does come with both halves, one NDS is in the hub still, and it does come with the little chainstay clamp and the barrel adjuster. 40H. 3 Speed KB3 Hub - £25 posted
I do have extra photos - and I'm in Tamworth if anyone wants to collect one bit or the lot.
