Tioga parts
I have a Tioga Avenger 1 1/8" threaded headset... went looking for it (you need ahead though... is that right?) and also found a 4mm Tioga ahead spacer (1 1/8") too :) I also have a Tioga front brake cable hanger for use in a 1 1/8" headset too, ideally a threaded one :?
Thank you for checking. Yes, I need a threadless/Ahead headset, as I already have the stem I wish to use.
I do have a Tioga cable hanger, though I'd not considered whether it's suitable for Ahead!
The spacer may well be useful - I won't know whether I definitely need it until I find the headset. Is it alright if I get back to you as to whether I need it?
Thanks for your help.
yeah whenever bud, having a clearout at the mo but even I am not tight enough to advertise ONE ahead spacer (or am I?) :twisted:
if your cable hanger is to go in an aheadset I'd personally go for one with a pinch bolt, but mine would work too (think its for threaded... can't actually remember if mine has the little notch thing in it, but if it does that can easily be filed off as its alloy. That is if you definitely want to keep to the Tioga theme!) Mine looked tatty so I had it powdercoated gloss black with a frame a while back.
I have most the parts I need now, but I'd like some early 90s Tioga Power Studs bar ends. Preferably in black, but silver might work.
have got some silver tioga power stud bar ends, do you have a pic of the ones you're looking for?
idealy i would like to swap for a pair of silver or purple answer hyper ends.
grtz,
Danny
I'm looking for either the shorter:
or longer:
one in the style above.
Black would be perfect, silver might be alright ... I'd have to try mocking up an image or something to get a feel for the scheme.
I don't have any Answer Hyper Ends to swap though.
they are the shorter silver versions.
i will send some pics of them after the weekend or so. send a pm if i forget.
price: no idea. will take a look what hyperends go at ebay or rb
grtz,
