Parts Clearout
boxxer
MacRetro Rider
Original Hope Big Un laced to Mavic 521 CD (96) - Front - 32 Hole Blue 20mm bolt thu. Takes 5 Bolt disk - could be run as a rim brake if you wanted £45
Original Hope Big Un Laced to Mavic 521 (01) - Front - 36 Hole Blue 20mm bolt thru. Takes 5 Bolt disk - could be run as a rim brake if you wanted £45
Hope C2 caliper half for 74mm post mount - no piston but difficult to lay hands on these anymore..... £10
Hope Rotors - £7 Each
Hope E4 / M4 185 6Bolt
Hope E4 / M4 205 5Bolt
Mono M4 200 5Bolt
AC RH Crank - worn but well usable - £15
AC DH Ring 44 Tooth - £9 or £20 for crank and ring
OEM SPD Style pedals - little use - OEM on 96/97 Marin B17 - £10
LX Front Mech 31.8 Bottom Pull - Swap for top pull in same diameter or £7
Will post other parts shortly once I've figured out what needs to go....
might be worth contacting dyna-ti - he is after a blue hope front hub but i'm not certain of the exact model
