Masses Of Cannondale Headshock Parts - More Added
FRSMark
Part of a job lot I bought, as follows, all NOS.
All prices posted.
Sets of 4 Inner Bearing Races for Headshok with 60/70mm travel BEFORE 1999
Length 133mm
£6 per set
HDR2D/022 0.559mm (0.022") x 1 set
HDR2D/023 0.584mm (.023") x 5 set
HDR2D/027 0.686mm (.027") x 3 set
Set of 4 Inner Bearing Races for Headshok with 80mm travel
Length 144mm
£6 per set.
HDR2F/014 0.356mm (.014") x 3 set
HDR2F/015 0.381mm (.015") x 4 set
HDR2F/016 0.406mm (.016") x 2 set
HDR2F/017 0.432mm (.017") x 5 set
HDR2F/018 0.457mm (.018") x 5 set
HDR2F/019 0.483mm (.019") x 2 set
60mm-70mm HEADSHOK after '99
£6 per set
HDR2E/023 x 8 Cannondale Inner Races
HDR1A/040 x 1 Cannondale outer races
Headshok outer race retaining tool
HD137 x1 Recommended for Fatty forks - £10
HD170 x15 Lower circlip for headshok cartridges - £1 each
QBDCF x 1 pack of 10 Coda Expert Compact Disc olives & inserts - £2
QBDR/MHW x 3 packs of 8 Coda Expert Compact Disc rotor bolts - £4 pack
HD135/BLU x2 (medium) MOTO FR SPRING KIT Triple clamp forks introduced 1998 £10 each
HD104 damping shim kits x3 (Fine tune your damping) Brand new with installation instructions etc, compatability:- FATTY and MOTO forks only. £5 set
HD179 x 6 TOP CAPS with screw, original spec for FATTY M forks.It's not a turning lock out dial.....its just a top cap. - £4 each
QSMSEAL x 7 Headshok top headset seals. - £2 each
Can i get dibs on the HD137 outer race tool and HD178 top cap pending pictures, need pics of the underside of the top cap to see if it is the right fitting for my forks.
CODA Rotor Bolts - QBDR/MHW - 8 per pack, I have 3 packs - £4 a pack posted.
HD104 Damper adjustment shim kits with instructions Fatty/Moto- RRP £16 - £6 posted, I have 3 sets
What does the outer race tool look like?
Unfortunately it doesn't look like the right top cap, I need one with a grub screw in from the side
This......
red_riviera":1gmhlfss said:
Don't suppose you have a headshok installation tool ? (it's just a tube of the right diameter I believe)
Sorry no I don't.
Mainly bearings, seals, springs.
