Jump Frame, Marzocchi Parts and other bits UPDATED 30/08/10
danee74
Hi All having a small clearout. Click pics for larger image.
First up, DDG Black Jack frame, 14" c-c, paint a bit tatty but would probably polish up ok if you dont mind a few chips and dings, been mucked about with this one before so its now £28 collected or £34 delivered.SOLD
04 Marzocchi MX Comp forks, these are being sold as spare parts, they have had new seals and bushes twice to try and solve the problem of real bad flex almost like hinging in the middle. When you brake the front wheel tucks under by an inch or so really scary and they feel squirrely too. The lower bushes have now been forced in too far. Strictly for spares so £28 deliveredSOLD
Whyte SL620 riser bar, nice and light, 620mm wide with a small amount of rise, a few marks. £15 deliveredSOLD
No Name Ahead Stem, 1 1/8, 65mm long with a bit of rise for standard bars. £5 delivered SOLD
Full bikes worth of M600 LX V Brakes, one bolt has missing washer and pads are pretty worn. £12 delivered SOLD
Deore rear mech, mega 9 compatible. £10 deliveredSOLD
Ritchey Logic 1 1/8th Aheadset, a little worn but bearings are good. £10 deliveredSOLD
Brake studs from an aliminum GT (Aggressor I think). £5 deliveredSOLD
Brake studs for Marzocchi forks. £5 deliveredSOLD
Cheap and cheerful-ish 6 speed thumb shifters. £4 delivered SOLD
V brake arms, 2 pairs, no pads or hardware. £2 delivered SOLD
Truvativ Firex 170mm non drive crank arm, square taper. £5 delivered
Iron Horse (read Lead Donkey) Huuuge frame, proud to be made in Taiwan of the finest Hi-Ten Steel, bit rusty, horizontal dropouts so ss hack a possibility. Comes with forks and headset. Nice old school style. £15 collected, will post at cost but won't be worth it as it wieghs a ton!
Tioga saddle, rusty rails, one rip on edge and really bloody uncomfortable to boot! £5 delivered
DMR wingbar, steel, 700mm wide with 3" rise, could do with a paint. 25.4mm shim included £10 delivered
Old and funky alloy stem, 1", 25.4mm bars, 100mm with loads of rise. £4 deliveredSOLD
Nasty steel bars, 660mm wide, 3" rise, these have a bulge in the middle 25.4mm and have a fair bit of sweep backwards, £5 delivered SOLD
i almost dibsied some of these just for the amazing descriptions
"wish this could be a bigger bump" type bump :D
PMd about the cheap and cheerful-ish thumbies, the V arms (no pads or hardware) and the nasty steel bars.
inittowinit":5eciv86n said:
anything youd swap the ddg for! 8)
Would consider a Thompson post in 27.2 x 400mm flavour or a nice 1 1/8th stem for oversize bars 60 to 70mm.
What have you got?
