Wanted Hope pro 2 Evo parts
ishaw
GT Fan
I took a hub apart ages ago to service, but seem to have misplaced the internal spacers and probably the freehub spaver/washer.. anyone got a broken hub or slate bits knocking around?
I'm sure the bits I've missed will turn up eventually but I've looked everywhere and impatience/laziness is getting the better of me.
The standard freehub version, I think they only has single speed in stock when I checked, or XD driver which are both shorter.
Just checked and they seem to only have xx1 and microspline for the pro2 Evo in addition to the ones mentioned.
I've not looked at an exploded diagram for a while but think I just need the spacer that sits between the two freehub bearings that spans the cassette section, and the washer that slots on before the freehub. You said you had 2 if the 3, what's the third one?
There are 2 spacers in the freehub and the 2mm steel one between freehub and hub body. You best check on the Hopetech pages.
Items 11. 12 and 13.
I've almost got all the bits now, just need the little spacer that sits between the freehub and bearing now. Anyone got one?
