Hope C2 Disc brakes front and rear + rotors
captain black
Complete C2's
front - Lever, original fat black hose, No.3 half caliper-standard fit, green pads, 185mm 5 bolt rotor.
rear - Lever, original fat black hose, green pads, No.2 half caliper -
will fit early non disc mount frames via axle attachment and torsion bar (supplied) to v brake boss, or change the half caliper, still plenty out there! 165mm rotor.
good brakes, good price.
£60
post n message pls
cheers
Rich
further pics....
C2'S tech stuff!!!!!
JST TO CLARIFY
they are full calipers, when split each numbered section is a half caliper,eg -they are interchangeable on c2's allowing for different fitments to the rear caliper body to fit different frame mounts or old standard fork mounts.
these were bought frm new, they do not come with a skewer, any standard rear skewer goes thru in reverse eg- the skewer lever/head is tensioned on the gear side of your frame, against the caliper/nut assembly on the left/ disc side.
included is
front complete-lever, hose, no.3 caliper- standard fit, 185mm rotor, 5 x bolts.
rear complete-lever, hose, no.2 caliper- plus torsion bar & brass spacers(fits to v brake mount) caliper axle/cone insert, nut/washer and and threaded tensioner-attaches to end of standard skewer), 165mm rotor, 5 x bolts.
everything to fit non disc mount rear of bike, there are no missing parts.
(or change the no.2 half caliper if you have disc mounts, less complicated)
cheers
