Hopefully someone can tell me where I'm going wrong and call me a numpty.
I have a Carrera Subway (I’m not proud of it !), about 7 years old. It has loose bearing hubs,
I took them apart to clean/regrease and I just can’t get it to go back together properly.
When I first stripped the bearings out they were sitting in Groove 2 and there was at least one ball missing making it wobbly. When I tried putting it together with 9 balls and lots of grease did the cones up fine. First time I rode it balls started to jump out from under the cone into Groove 1.
I got a cage bearing as I couldn’t find loose balls locally, the cage happens to fit perfectly in
Groove 1 ! Tho the cone doesn’t seem wide enough to hold it in. I was going to pull the balls out
so I have enough loose ones.
Anyone got any tips or a diagram (hub is unbranded Halfords special).
In my defence, I sold it a couple of years ago to some W***er who mucked me about. I took it back but noticed the hubs were very loose (he’d taken everything apart !). So I never saw the hubs with everything correct before I sold it. Has he put the wrong size balls back in (they are 1/4 ") or something stupid like that ??
