Gripshift 7speed model CX-DT 225 for Suntour XC Pro Sorted
Re: Flite original. Early MK1 Gripshift 7sp. Campag crank bo
PM coming for details, thanks.
I've got 15mm crankbolts, or 14mm
May have the syncros bit too, I had a pin break but kept the clamp.
Let me know if any use.
Martin
Syn part sorted and Campag bolts too just this morning, thanks.
Re: Early MK1 Gripshift 7sp.
Which one do you need?
I still got a NOS box CX-DT 118 for use with Shimano Dura-Ace 7/8sp....
Hi Arie,
I don't know the model number that I require and I am not sure if these will work, is this what you run on your Backfire?
Cheers, Ash.
hi Ash,
i have a set of CX-DT 225 on my Backfire, but i bought the CX-DT 118 to see if i could adjust them to Suntour. In the end i never tried this, because i found the 225....
You want to use it with Suntour XC Pro?
