:shock:Will someone please answer my question now?
What is the question? This thread confuses me!!
Sheepdisease":a4nvpg51 said:They would simply replace the v-brakes without having to change anything on the handlebards?
daj":1aeg963s said::shock:Will someone please answer my question now?
What is the question? This thread confuses me!!![]()
i don't think that new v-brakes will change anything because the xtr v-brakes are said to be one of the best. what condition are your brake pads in? how much do you weight? what kind of brake levers do you use? how did the bikeshop mechanic explain the weak braking power?Sheepdisease":1a0b50s2 said:Hello, I know it's been a while but I've not changed anything regarding the brakes. I've had the bike serviced a number of times now and things haven't really improved. So I was wondering what v brakes to get for the front and rear? The avids have been discontinued...
Inigo Montoya":3svebmz0 said:i don't think that new v-brakes will change anything because the xtr v-brakes are said to be one of the best. what condition are your brake pads in? how much do you weight? what kind of brake levers do you use? how did the bikeshop mechanic explain the weak braking power?Sheepdisease":3svebmz0 said:Hello, I know it's been a while but I've not changed anything regarding the brakes. I've had the bike serviced a number of times now and things haven't really improved. So I was wondering what v brakes to get for the front and rear? The avids have been discontinued...
i'm using v-brakes on my main ride and they are frighteningly strong. thats why i'm sure that there is something wrong with your setup.
surpised to hear that your bikeshop didn't swap the brake pads for new ones. if they are extremly worn i'd get new ones.Sheepdisease":3a04xfie said:At the very least I need new brake pads, they are extremely worn. I weigh 12 stone. What kind of brake levers? What types are there? They look pretty standard to me. They tuned the brakes to the rims that were on the bike at the time, but I put others on because I wanted to use slicks rather than mountain bike tyres. Then the wheel would hardly move because the brake blocks were too close to the wheel so I loosened the brake cable and adjusted the metal things on the ends of the brake levers. That was when I noticed how worn the brake blocks were.
