GT Zaskar Pro 2006
Markbsi
Always wanted a Zaskar when I was younger and this frame came up cheap locally a few years ago. It's sat in the shed for years with the intention of building it but as usual life got in the way.
Last year I decided it was time to get it built and start enjoying it so after months of collecting parts, it's almost finished. I still need a couple of things, a shorter stem and new decals for the forks.
A cheap 2008 carbon zaskar frame appeared locally on facebook so I bought it and swapped everything over. Unfortunately I'm not that keen on the blue of the new frame with the red parts.
In 2006/2007 I bought a Zaskar Team frame and had it built with spare parts from the LBS. My first ‚proper’ mountainbike to go racing with. Fond memories indeed.
Hi, I have virtually the same frame only mines a 2007, I’m in the phase of collecting all my parts ready to build up the frame but I’m a little stumped as to what type of headset to order. My last couple of project bikes have been Avalanches which take a semi integrated type headset 44mm ID(cups pressed into frame) the Zaskar however is 41mm ID and I have a feeling it may be integrated (bearings pressed directly into frame no cups) question: do you happen to know what headset you used in your 06 Zaskar?
