V brake power modulator
There's a dial on that one. Put it up to 11.
But you don't know where 11 is. Is 11 High or Low? Is High more Power Modulation? Is High better Stopping power? What could Low be?
Snowflake to the left, parasol (umbrella?) to the right.
I genuinely have no idea which way to move the light. Snow = colder fridge or snow = colder weather so warmer fridge? Parasol = ‘warm outside, make fridge colder’?
surely with the centrigrade to the left, that means it's in centrigrade from 2 to 8? then frost and to warm at either end?
probably not. :)
Sounds logical, but my brain can’t square the optimum temp of a fridge (3-5 degrees) with a control that allows a temperature of 9 degrees.
Who needs to run a fridge at 9 degrees? It’s positively frowned upon by those who care about food hygiene.
I didn't say I understood it either. :)
who knows, it might not even be 9 degrees, it might me heat and your fridge is also sold as an air fryer. :)
What "9" ? Its obvious the fridge is rigorously calibrated and certified between snow and a parasol.
Will you be having that Classic Chicken tomorrow?
