Wanted 52/53cm frame for neo retro build
I have a couple of frames. One is a Peugeot 531 that needs a re-spray and the other is more modern Scott aluminium team issue frame which I have to say is extremely light. The Scott is frame only so needs a set of forks. I would be happy with 25 pounds for either one or both for 45 pounds. If you’re interested I can get a few pics.
Hello, thanks for the reply!
I am interested, please can you send over some photos.
Joseph
Joseph
No problem, here are the frames. The Peugeot is an Optima 14 originally and has 126mm rear spacing. Obviously an older frame than the Scott. It has a Tange Levin headset that might be ok with a good service. The original seatpost is also there. The Scott is as you can see, it needs a set of forks.
