Wanted Seatpost binder bolt in blue
JimboG
Looking for something like this. Anything out there please?
I have a Zero quick release skewer that's mint if your interested?
Was looking to stick with a simple bolt ideally mate but thanks for the offer. Also a little dark blue as most of my parts will be more turquoise 👍🏼
If it’s 37mm it may be a tad too short. The clamp width I have is 34mm so the end bolt would only be screwed on by around 3mm which I don’t think is enough.
It's from a steel frame which clamps a 27.0mm post and there isn't much / any thread protruding so you may be correct. With the bolt flush with the end of the nut the verniers measure 27.25mm of internal bolt (funnily enough) so it is probably too small. No dramas.
