I've spent way too much time and money trying to sort what should be a really simple part to fit.
My frame has replaceable M10 canti studs front and rear. I had to get new sets because the old ones were knackered - so far, so easy.
But every pair I can find has a larger-diameter part at the base that is preventing my cantis from reaching the bottom of the boss. In turn, this means the spring pin barely engages with the hole in the frame and pops out at the slightest rotation of the brake. The picture hopefully illustrates what I'm on about.
What's going on? Looking at an old steel frame I have, the canti studs don't have the larger diameter part (and lo and behold, brakes fit fine). I've tried Shimano R550 and Tektro CR710 cantis, same issue with both.
Thanks for any advice. I hope that makes sense.
