Sold 1994 Mountain Cycle San Andreas starter kit
youngsspeed
Mountain Cycle Fan
Offering for sale:
1994 San Andreas frame with 1993 System 2 Suspenders forks. The frame still has it’s original coating and is all original. The frame has the very hard to find Risse shock upgrade. The shock still holds air.
The forks compress and rebound. They are not stuck.
Also includes the uber rare Pulstar front disc hub for Pro Stop brakes. Installed on that rare hub is a 1995 Pro Stop front rotor along with 1997 Pro Stop FH front caliper and lever set.
Also included is a matching NON DISC Pulstar rear hub.
Frame has a Syncros Ti seat post installed, but I can swap that for a Syncros black aluminum seat post if desired.
Also included is Azonic stem and riser bars.
Also included are straight head spokes for the Pulstar hubs. If memory serves, the length is correct for M231 rims.
Also included is a FSA Pig Pro DH headset. It has spacers to fit as the frame is for a 1 1/4 headset.
The bad:
1) there is small crack, as shown, on the seat mast directly below the seat clamp. It is easily repaired but I just don’t have time.
2) the steering tube has been replaced with a 1 1/8 aluminum tube. So the headset race is not super tight on the tube seat. It is not loose, just not super tight.
3) the socket head on the forks top caps are worn and rounded.
The front brakes is in unknown condition and is untested. There is still fluid in the line, along with air.
Shipping is from California, 2 hours north of San Luis Obispo where the frame and forks were hand built.
This is a great start as all the hard to find parts are here.
Asking $1100 USD PLUS all shipping costs
