For Sale DURA-ACE 7700 rear mech , Campagnolo Veloce 34.9 front mech , 700c steel forks, long 1 1/8” ahead steerer. Canti or V mount, pannier & mudguard mounts
Minifreak
Hey guys,
Few road related bits I have no current use for as I only own mountain bikes.
Price shown plus postage, happy to send worldwide.
SOLD Shimano DURA-ACE RD-7700 rear mech in lovely order. £30
Campagnolo Veloce front mech, 34.9 band, bottom pull. There is a split in the clamp, I guess someone used on a smaller frame. It’s near the thicker section of alloy so will be fine to mount and use. £8
700c steel forks with 1 1/8” ahead steerer, 217mm from crown, SFN fitted, pannier and mudguard eyelets. £10
Hi,
I'm interested in the rear mech - but there seem to be three or four versions made and my searching is going nowhere!
Do you know if it will work with a triple front ... or do you knw the capacity?
My front ring is 52-39-30 and the rear is 24-11.
Thanks
Campagnolo front mech
☹️ Darn that's a shame - I think I need the mid length version .... which I think has a larger capacity.
Thanks anyway ...
It has a larger capacity in chain wrap, so can handle a triple up front or larger chainring difference. However the geometry is the same so it notionally cannot handle anything larger than 27T on the back.
That said, usually you can push things a bit as Shimano is conservative.
