For Sale XT 739 mini group
InFaasion
Working condition. STi's in good condition (including plastic adjuster inside lever), deraillers have both cosmetic corrosion. Front 34.9 down pull, rear long cage. Brakes are in good condition with non broken plastic housing around springs. Bolts included. Happy to ship from the Netherlands. 250 excluding shipping.
They fit both. The shims can be removed to make it work both Canti and V’s. See Shimano product picture where both are shown.
So you are saying that removing the small wedges allow them to work with cantis on M739 levers?
If that’s the case why do they show the M738 levers …..
Interesting, what shim needs to be removed from where to make these levers canti compatible?
Sorry to hijack your sale thread, but I fitted V's because i assumed these levers wouldn't work with cantis, which I'd prefer to use.
GLWS!
GLWS!
On the lever itself there are the small half moon shaped shims. Two per lever.
I’m not a Shimano expert but I believe they weren’t designed for them to work with cantis. If removed they make change the feel / power of the V brakes.
M738 levers as shown on that pic were the canti ones
