baron von greenback
Office wall if your going to buy it wouldn't you build each to there own I suppose
Superb work, as always, Dan
Exceptional work as always.
Pretty good deal. Especially if you are able to extract the seat post yourself, do a little welding job to repair the cut, reproduce a new side for the hub and have it anodized again.
Then, sell the hubset, the hyperlite bars, the serviced fork and the headset.
Nice project for a totally ok price in the end!
You say reproduce a side for hub how do the hubs come apart cheers and what's a f ame like that worth thenPretty good deal. Especially if you are able to extract the seat post yourself, do a little welding job to repair the cut, reproduce a new side for the hub and have it anodized again.
That's almost unbelievable work.Repairable, though.
I spliced a whole new top section into an Ultimate many years ago:
Lumpy tube from bad reaming and a crack repair:
Replace with this fresh tube:
Cut out seat tube and file back joints to the original mitre surfaces:
Machine a 2-way plug to join the original seat tube and the replacement section:
Dry run fit:
Weld it all up and file the joint back to the original surface to hide it:
After paint:
All the best,
