For Sale wide wide Enduro wheelset 26 - DT FR570 on DT350 hubs - aero spokes - handbuilt
2manyoranges
Wide puppies for COTIC, Stanton etc
Well, anyone who knows the FR570 rims knows that this is a bombproof but lightweight enduro setup - these were built with no expense spared - red alloy nipples, DT aero spokes. Rims are 30mm internal which means BIG tyres are possible on frames with clearance - Stanton, Cotic, OnOne etc. This wheelset has been looked after carefully and done miles on South Downs not Welsh slate or Northern grit. As those of you who have bought things from me in the past I carefully describe things and really look after my gear. I’ve moved to bigger hoops on all my bikes - 26 ain’t dead in our stable but it’s sure an endangered species…
Specs
DT 570 26 inch 30mm internal rims, decals all good, running perfectly true, no dents or dings.
DT 350 135mm QR rear, 100mm 15mm front. Bearings perfect. All disc threads perfect.
Set up tubeless - rear Maxxis Ardent, front Schwalbe Hans Dampf - both with few miles.
DT aero spokes with red alloy nipples.
Essentially one of the best weight-strength wheelsets. Perfect for chunky descents, light on the ups.
Mahoosive grip. Fit and forget. Handbuilt and spec’d by Kentish wheelbuilder.
150gbp plus postage
text to 07702505256 or PM here
blimey thought these would be out the door really quickly ... 700+ gbp wheelset originally ...
set up tubeless with Stans
What's the tyre width please?
Hans Dampf on front = 2.35 on the carcass actual measured with vernier at 61mm or 2.40 in old money
Ardent on rear = 2.25 on the carcass actual at 57.5mm or 2.26 inches
30mm internal advised tyre range, as your prob know, 2.2 to 2.6
Thanks
