Swap 2 Hope hubs for 1 black rear Hope hub
Alison
Front is 110mm x 20mm axle pro 4, the rear is 12mm x 135mm axke Pro 2. I want a rear 135mm x 12mm axle Hope Pro 2 hub in black.
It's basically a 2 for 1 offer 😁
Alison
Sorry for the delay. I only have pro2 Evo hubs not built, well a set of bulbs too.
I do have a pro2 hub built into a wheel, well pair of wheels, but I'm not adverse to splitting it.
Needs a clean, freehub is in decent shape, I believe bearings are good, but I can always replace if not (have the tools, probably bearings too, but if not I can source some). I should have done 12mm end caps but if not, your blue one has them so a simple swap if I don't.
If of interest let me know and I'll give it a clean and assess the bearings. I did clean out and grease the freehub when I got the wheels but I've not used them on a build yet.
Thank you for getting back to me
It is actually a Pro2 Evo that I have for the front hub, so the Evo version is what I am after, in black.
If they are 135mm
Alison 😀
