Camera Bag - Is a Custom Solution the Only Real Option?
SFP
Devout Dirtbag
As a professional photographer I have some very nice aka very expensive camera gear.
Traditionally I have used one of my Lowepro AW backpacks to carry my body and a lens or two. This has worked well for a couple of decades now, and when doing mild off road with the MTB is kind of the only real solution.
As I have gotten older heat and I are no longer friends so I am looking for a solution to carry a body and a lens or two.
Reviews all point to using a handlebar bag, a sling bag or backpack. All of which do not appeal to me.
Buying a used smaller point and shoot camera also does not appeal to me at this time (but may be what I end up doing in the end - any excuse to buy more camera gear is always good I suppose).
Myself, I keep thinking of using a truck bag on top of my rear rack on my city/pavement ride. This of course brings up the question of vibrations and bumps. Both of which are so not good for a modern camera.
My thought at this point are to take a smaller truck bag I currently own and cut up and use pieces from a traditional shoulder camera bag to make something.
I obviously want to dampen (EVA foam) as much road vibration and the occasional bump (coming off a curb, slight bunny hop on rear wheel going up a curb or what have you).
Before I start prototyping something I figured I would ask the hive mind if anyone of you have found something that works really well.
Failing that, full speed ahead and let the cutting and sewing begin I suppose.
I plan on documenting said build of a bag and hell if it works well, I'll spend the specs to Lowepro and say "go to town, but there is a market on this design" as to help out fellow photographers who ride.
Cheers folks.
Scott
I saw a pro photographer using a fairly standard ortlieb pannier, with a foam insert that had cutouts for the camera kit.
Bar bags are more swiftly accessible, and potentially better suspended, but smaller.
A larger tyre at lower pressure will reduce shocks - but possibly some components are more sensitive than others??
These could be "worn" in a waist bag for maximum damping.
  • Like
Reactions: SFP
I know you said backpack doesn’t appeal but…
F-Stop ICU inside a nice, suitably sized backpack, one with an air mesh trampoline type back.
No sweaty back, no bouncing around as a half decent backpack will have compression straps, no unnecessary attention drawn to the expensive contents.
  • Like
Reactions: SFP
I’d say the problem is not the bag but the camera. Dig out one of your old film cameras (or buy one): an old 35mm SLR or rangefinder will be happy enough off-roading in any bag with a bit of padding; or just wear it on your back with a trendy harness. (The latter would also work with a modern camera that isn’t too heavy - your body being the suspension/padding.)
