Rigid Forks Needed
Jimmi
My mate has an Orange P7 and he wants help to get it back up and running, the sus forks are totally shot. I’ve found some cheap rigids that have a 390mm a2c the ones I’ve removed are 450mm. Will this be too much of a difference? I’ve never done this before so am worried it’ll look a bit “nose down”
You didn't specify. Sorry, no.
I assumed discs, my fault.
Only suggestion I have is ebay. Not much use.
I should have been clearer. What I’m looking for is so hard to find! I’ve seen some on Aliexpress for £35 but don’t really want to go down that route. I guess I could convert the front to disc but then that’s a whole load of money. Or just run back brake 😏
You could try keeping your eye on eBay. Exotic carbon or alloy forks available with brake bosses.
Are you looking for threaded or ahead steerer? Length? Assume 1 1/8 steerer?
What forks are on it now that are shot? May just need new elastomers which would be arguably slightly cheaper than the forks you mention. Or they could just be shot.
