LondonClassic
The stiffness you mention could just be dirt so as a first go maybe some 3 in 1 or similar lube down the cable hole in the lever  - that can transform shifting. Failing that, I had my ergos brilliantly servced by year1cycles a few years ago - who while they were their fitted record internals into my 10sp Centaur R hand shifter. They can do all sorts of stuff, like add or remove speeds as well.
 . Comparing this bike with my 531-framed MB Dronfield from 1994, there's not much to tell them apart, they're both equally nice I would say on first impression. Both are the same size, with similar geometry, and this one weighs almost exactly 10kg, which is also very close to the MB (any weight saving with the 653 frame is probably negated by the use of Campagnolo parts...
. Comparing this bike with my 531-framed MB Dronfield from 1994, there's not much to tell them apart, they're both equally nice I would say on first impression. Both are the same size, with similar geometry, and this one weighs almost exactly 10kg, which is also very close to the MB (any weight saving with the 653 frame is probably negated by the use of Campagnolo parts...  ).
