1953 Holdsworth Whirlwind
Glug
Hiya Folks,
I promised to post some info on this, and I've just done the photo shoot.
Got if off Ebay last October as my state retirement present.
It's 23" with original paint which turns out to be cromovelato magenta, but the chrome is a bit missing and a bit rusty.
I repainted it with fake cromovelato - translucent enamel over chrome guilding paint. It's not quite cromovelato but looks ok.
Doing it properly would require rechroming and a good paint shop, but somebody could still do that one day.
I was persuaded by the nutters on bikeforums.net to try full period gear, and it does work. It's just not as slick or fun (yet) as my 1961 Holdsworth Cyclone with 80's SunTour gear (Cyclone + Power Shifters + New Winner ultra-6). I'm expecting improvement when I work out which bits need adjusting.
Current build:
Front: Cyclo Benelux mark 7 rod shifter + Williams C34 50/32
Rear: Cyclo Benelux mark 8 Tourist 5 speed + SunTour ultra-5 13-15-17-20-28 [-18]
Pedals: Lyotard Berthet M23
Bars: GB Tourmalet
Stem: GB spearpoint 70mm
Brakes: Mafac Racer
Seatpost: Campy 1044
Wheels: Campy Nuovo Tipo large flange + Mavic Monthlery Route + Vittoria Corsa Control 30mm tubular
Shifter: Simplex 50s
Bell: Crane Suzu 5cm brass - possibly the best bell ever
The rod shifter actually works really well - even shifting 18 cogs. I just takes a bit of practise to reach it.
The Simplex shift + Cyclo Benelux Tourist is more effort - but I'm still making adjustments and learning where the gear stops are.
Richmond Park yesterday:
Drive:
Cockpit
Bars:
Still a work in progress and I can't help thinking how well it would ride with a SunTour Cyclone GT on the back and Power Shifters :)
Edit: Full gnarly details at https://www.bikeforums.net/classic-vintage/1301557-1953-holdsworth-whirlwind.html
Not a bad job, looks really good! I’m amazed the rear mech can handle that much gearing. I haven’t put one through its paces but I was under the impression the Benelux only had a limited capacity.
Hiya Folks,
Current build:
Bars: GB Tourmalet
Brakes: Mafac Racer
The rod shifter actually works really well - even shifting 18 cogs. I just takes a bit or practise to reach it.
Drive:
Cockpit
Bars:
Is there a welsh connection or do you just like the flag?
Fabulous colour in combination with the ornate lugs. What's not to like about it?👍
The 1957 Cyclo Benelux mark 8 Tourist was available in 3, 4 or 5 speed and had a wrap of 35 and max cog 28.
Really quite impressive for the time.
I actually got it to work with a 32 cog but decided to stay within spec for the moment.
The 5 speed shifts the pulley 23.8mm so it only just handles SunTour ultra-6 24.5mm and works better on ultra-5.
Here's me making a cheap one: https://www.bikeforums.net/classic-vintage/1305983-cyclo-benelux-mark-8-tourist.html
The Cyclo Benelux mark 7 is the more limited range one.
1960 Cyclo catalogue:
At least one of your parents have a welsh connection, i would think. It's not easy for all to pronounce that name correctly 😀.
Both, and my sister was taught medecine by JPR Williams
I think I saw JPR once in a hospital I was at when he was doing the rounds visiting patients. I think it was either 77 or 78. You don't forget those sideburns in hurry😄.
