D
Deleted member 57380
@Welshphil
Hi Phil, the head tube is the section of the frame that the fork inserts into, and it usually has the bike's logo as a decal, badge plate, or engraving. The bottom bracket is the cross tube that holds the crank spindle and bearings assembly. Usually, the thread specification is indicated on one or both of the exposed ends of the bottom bracket bearing cups where the crank arms attach. Thread types: Italian= 36mm x 24 tpi; French= 35mm x 1mm (25.4 tpi); Swiss= 35mm x 1mm (25.4 tpi); I.S.O. British= 1.37"- 1.375" x 24 tpi. Most bottom bracket shells are 68mm, or 70mm (Italian) in length.
Note if you plan to remove the bottom bracket: Italian and French cups are all righthand threads; I.S.O./Swiss are righthand threads on the left side (non-drive side) cup and lefthand threads on the right side (drive side) to prevent loosening from precession (left side pedals are also lefthand threads). I assume it has I.S.O. or French threads though French threads may have been phased out by the time your frame was made (~mid '80s). I doubt a Belgian builder was using any Italian dimensions although I am sure there are exceptions.
