Suggestions for a lightweight (folding) 26" x 1.5ish slick tyre?
Fatal Swan
I've got a bike with a 26 x 1.5" Schwalbe City Jet slicks on, and while the width is what I need for this bike, the tyres are heavy (I think about 600g each) and feel sluggish on the road despite being fitted on a nice lightweight Roval wheelset. I'm looking to save some weight off the bike anyway, so I'm looking for recommendations for a lighter folding slick tyre around the same width?
Was looking at this too: Pasela Protite seems best of the current crop - sub 500, amber wall and if the 700cs I had are anything to go by, roll nicely.
I’m also tempted by Michelin Country rock, which aren’t very light but are very cheap!
Rene Hearse has a 1.25" (Elk Pass) and a 1.8" (Naches Pass) in 26". They're quite light (185 and 295g, in extralight), and really not cheap. I've got a Naches Pass on the front of my tandem, and I'm completely happy with it.
i had country rock tyres on my commuter bike and they lasted for ages and gripped really well.
i would love them again but they are like rocking horse wotsit and everyone that i find that have them in stock want the worlds gold stash for them.
Yes, there was a batch on eBay recently that I missed; bikeinn have them: postage is 12 but they’re only 11.50, so 2 to your door for 35.
Thanks for the responses so far! The Michelin country rock at 560g are a bit more than I was hoping for, weight-wise. Those Naches Pass tyres would be amazing but look too pricey realistically and maybe too extreme at the other end - I wonder how robust they are?!
I've been looking at Maxxis Detonators which are 26 x 1.5 and 440g in folding (https://www.sportpursuit.com/catalog/product/view/id/3445233), but only seem to be available from China at the moment.
I've had the narrower version of the Panaracer Paselas Protite on other bikes and been happy enough with them. Even those always seem to run narrow to me (the 32mm I had were the same width as the 28s on my road bike) so I could look at the 26 x 1.75 which only seem to be in wire bead, 460g.
How robust are RH tires? It depends. I’ve had 10 individual tires, in 5 sets. I ride road, but the road quality is a step above gravel. I didn’t notice that they were unusually susceptible to flats, though I have had a couple of bad days out. Hawthorn thorns will go through them. I usually run ultralight schwable tubes in them, not tubeless, because I’m allergic to latex and I just am not going to deal with that.
On the Single bike, all extra lights, including some commuting to Dublin on the first and second set. 1 set (700x35) was taken off the bike after 2500 miles, because I went from 700c to 650b wheels. There was still life left in them. 1 set (650x42) I wore out in 2500/3000 miles. The rear sidewall threads started breaking on the diagonal where the single stabilization threads are, and this wore diagonal lines in the tube, which failed. This was probably from running super low pressure (well below their tire pressure calculator's low number) for too long. The front was fine for another while, (with some heavy thing on the back) but I took it off to go to to the third set on that bike, 650x48. They’ve got about 2500 miles on them now, the front seems barely worn, and the back has some noticeable wear, but maybe 1/2 life left. I’ve just rotated them, so we’ll see.
On the tandem, went from city jets to extra light naches pass on the front and a standard rat trap pass on the rear. Gained about 1.25 mph in average speed from that. Rear lasted 2500 miles, front was fine and lasted a bit longer till I replaced both (same sizes) with standard casings, The rear failed in about 1000 miles, front is still in great shape after 2000+. The rear failures were both due to the casing failing just above the bead, right where the thicker portion of the bead ends. I think what happened here is that the rim was old and narrow, used cloth rim tape, and the bead never really sat right. So the tire was extra folded there, and it eventually failed. They (RH and the Distributor) said that I must have been running the brakes into it, or my tire pressure was too low, but I’m 100% certain on the second one that the brakes never rubbed the tire, nor could they have even reached the place where the failure was. On their recommendation, I ran the pressure higher on the second one, but it failed faster. I chalk it up to a slightly missized rim, which has now been replaced. I’ll probably buy another set when what’s on there wears out.
For reference, I was going through 700x25 tires in 1500-2000 miles to the point they had noticeable shoulders in the rear and cornering got interesting.
TLDR, they’re not super fragile on road, so long as you’re not running super low pressure and get the bead seated correctly. On the other hand, if you tend to get sidewall cuts, you might want one of the heavier casings.
I have run Schwalbe Marathon Greenguard for 10 years or so. They are surprisingly fast (have a look at bicyclerollingresistance.com) and very puncture resistant. While they are wired they do very well.
