Konas, lots of Konas.
The code for the green is X15 and for the black it's X1.
The purple is a funny colour i tried it on a black stem and i wasn't to sure so didn't want to risk doing a whole frame and forks and ended up doing the blue.
I think though that if it was less purple and more green it would probably work,thats the fun part of splatting you never really know how it's gonna turn out you've just got to go with your own gut feeling.
Thanks for this information much appreciated.
The paint will be arriving on Saturday and Ill make some pattern boards to try and see how much of a mess I'll make of it when the weather warms up
Thought i'd personalise the Lavadome and the 90 Explosif like they done with the custom 89/90 Konas
Decided to switch back to the trusty Project Two's and saying i had these black ones spare they've went on purely for looks so it's matches up with the black Velocity stem.
I've removed the designed by Joe Murray stickers because that wonky one on the driveside was doing my head in 😂
Finally a 1993 Kilauea in the right size being 19" arrives back in the sanctuary 🥳 and i can now do my own one of one Kilauea 😁, i've started a separate build thread for it because it deserves it because it's gonna be mint when it's finished 😁
And i've also been having a ponder on how to make another one of one 93 Explosif 🤔
So one bike has inspired me to do three builds, which bike you ask,well it's the 93 Cindercone i've just got.
Part of why i wanted the Cindercone was some of the parts what were on it which i could use on the other Konas. And it also frees up some parts i was going to use on the 93 Explosif which can be used on Lazarus instead to resurrect it from the dead again.
So for the 93 Explosif the X-Lite titanium bars, XT Shifters and the Ritchey Logic brake levers are perfect with the levers and shifters being standard on the Explosif that year. The bars are a bonus but have also gave me an idea on what colour to have it powder coated if they can get a perfect match. Saying i don't have the funds for a 93 Hei Hei why not make it look like one 🙂 which also may lead me down a rabbit hole of cost because i'm already thinking i'll need a titanium seatpost to match the bars and maybe a titanium stem 🤔🤯
The other idea for the Explosif was to make a 1990 Explosif tribute bike which means a whole different set of parts for it🤨
Back to the Cindercone, i've been after one for years and years now constantly getting outbid or they've just been miles away with no postage so to see this pop i had to take a chance and get it and as a bonus it had suspension forks which still work 😳 I'm keeping the forks on this because basically the Cindercone and Lavadome share the same frame so it'll be interesting see the difference between rigid P2's and suspension.
So the second to last photo is how i bought the Cindercone and the last is how i've mocked it up with some DX parts. The big problem with it, yep the seatpost is stuck but not just one there's another in there aswell 😳😂🤣 i can see some temper tantrums happening getting them out 🤯😢
Which leads me onto Lazarus the Lavadome which i've owned since new this is the bike what made me love Konas so much.
Where do i start with the poor thing, actually i'm surprised it never phoned Kona to report me for abuse,this bike has took such a beaten over the years🤣😂🤣😂. The memory's come flooding back just looking around the bike all the dints and rewelds lol I'm sure it's thinking not again i've been chilled lying up in the loft for the past 12 years and now you want to build me up again 😵
I'll go into more detail about the bike as i go along but the plan is to get it back to as close as possible and also if i can remember every part i had on when it was in its prime. So straight away i'm using the Sugino 500 cranks off the Cindercone they should be 450's but they'll do. I was using the carbon Easton bars on the 93 Explosif but i used to have them on the Lavadome bitd so they can go on. I done alot of upgrading to XT back then when i could afford bits so i've found some spare M735 parts i had and they can go on. I'm tempted to put XT V-brakes on because as soon as they came out i had them on the bike and this was how i dislocated my left shoulder testing them out in the street doing brake tests outside the house. Basically ride flat out till i was level with the gate post and slam both the brakes on, mark where i stopped, rinse and repeat after every half moon removed until none are left and they're at full power. Stopped dead, over the bars dislocated shoulder 😵 yep there powerfull, taxi to the hospital to get my shoulder put back in 😂🤣
Right enough waffling time to start the builds 🙂
It's safe to say you love Kona bikes then... 😁
The overhaul of the 90 Tribute Explosif has started after getting bored of the XTR look,i want it to look more in period so it's been fitted with some Deore XT M735 and Deore parts just waiting on some new cables to turn up, so far so good.
Nearly went anead and built the bike then it dawned on me that i hadn't polished the frame. Quite a few coats of Muc Off Miracle shine later and it looks the business in the sun now the colour really stands out.
Here's a couple of photos i took to give you an idea how it changes depending on the light,there's some where i'm facing the sun and some where the suns to the back of me going directly on the bike and one in the house just under natural light coming in,i love it 😁
The cables arrived so now to get it built ready for a Easter bike ride.
I just picked up this 93 Fire Mountain, very cheap but very grotty. I am wondering what to do with it. Just checked over the obvious bits and the score is:
Good
- Frame is OK no really bad rust nor any dents
- Seat post not stuck
- Stem not stuck
- Gears work (Deore thumbies)
- Chain is newish and not worn (but strangely too long.)
Bad
- Wheel rims are toast
- Chainset is rusted to hell
- Headset looks toast
Not checked
Bottom bracket.
Any thoughts what to do.
1. Fix up as a working bike out of the parts bin
2, Restore
3. Part out.
4. Resell as is
It looks as though I could sell the thumbies for what I paid for the bike, let alone the P2s and stem. Damn I could probably get half what I paid for the dog collar and seat clamp.
I gave the bike a good scrubbing, sprayed it with WD40, took off the strange mudguards and I'm actually growing fond of the old girl. I think I have a crankset that will fit, some bog standard v-brakes and some stis (since nobody actually likes to ride with thumbies and they are worth more than the bike ;) ) Some decent wheels I have lying around waiting for a home and it will make a decent bike for someone.
