For Sale Avid brakes, FSA PowerPro, VP bear traps, XT rear mech...
LikeClockwork
Kona Fan
Okay, so this stuff has rust, dirt, and scratches, and will need cleaning/polishing, but it's all functional. Mostly came off a bike I bought for the frame.
Postage is 2nd class with RM, add £3 😁
FSA PowerPro (I think) crank arms, 175mm. Lacquer coming off, faint graphics. Good tapers/threads. Bought these a while ago off Ebay, but they need a 94bcd ring, and I haven't got one.... £15
XT long cage rear mech. Strong spring. Lots of scratches, and there's a plastic outer cable end stuck in the cable adjuster, I had a go at getting it out but got grumpy, easily solved by someone else I'm sure 😆 .... £10
Happy to combine postage, obviously, if you take more than one thing and it stays under the 2kg weight limit for small parcel.
SOLD STUFF -
VP (I think), ratty bear traps. Loads of paint loss, rust on spindles, dry bearings, cages have a couple of loose screws/rivets. Easily salvageable if you've the patience.... £3
Avid Single Digit 5 V brakes and levers, rust on bolts, bit chewed up on the little dials on levers, but they still work. Probably enough meat left on pads to be usable for a while.... £15 the lot
Just a thought, 48hrs isn’t a long time to advertise bike bits for. Not sure what the frequency of people logging on is but I don’t reckon it’s every day?
Yeah, quite possibly you're right, but in my experience over the years, if stuff doesn't go pretty much straight away, it doesn't go at all... but then Ebay's gone to crap so I probably won't bother with that either 😆
Sorry, didn’t mean to tell you how to suck eggs!
